Hesitation when accelerating?
Deegle
Hello All!
I have a 2015 Ecodiesel with 106k miles. It is stock but for a K&N cold air intake. I use hotshots fuel treatment regularly. Lately it has been hesitating under acceleration. If I floor it, the hesitation is very bad and the truck jerks violently. This is particularly pronounced when the vehicle is cold. Sometimes when I drive it though, it is fine and does not hesitate at all. Any ideas?
Thanks!
694
This is likely your problem, in addition You are hoping you Don't have warped Intake valves.
Deegle
Thank you. Is it difficult to remove and clean?
694
At Your Mileage Replace...Have you had the ERG update done?
mikep4363
Hi gents,
Any updates on this hesitation issue. I find it more prominent in morning Start...I did replace fuel filter, and intake manifold. My manifold was really gunked up but I cleaned the runners and replaced manifold....still exhibiting same symptoms. No codes at all...I'm pointing towards fuel pressure. Any thoughts
Forgot to mention it's a 2015 with about 120xxx miles
