welded
Hey welded,
You have my trucks twin...hopefully this new motor is better for you.
Thats a fine looking truck you have there. cheers
Cliffy
20
I have put on 105 000 Km's since August 1, 2015 and have had an average fuel economy of 9.46 L/100 km (24.864 mpg). But I wanted to get a new truck while I have a good trade in value, and the deals right now near me were too good to pass up. So I am getting a 17 Hemi Big Horn to hold me over till I can get another light duty diesel. I'm going to stick around reading this forum to keep me up to date for my next diesel truck.
John Segale
I'm at a little over 27k miles now. No probs at all.
Recently leveled, load lifter 5,000 air bags in rear, and 20" Fuel Recoils.
382
137
Hate to jinx it, but 2014 now with 45,000+ miles. Warranty replaced DPF and CAT, occasionally get the Throttle Position System service code which results in Low Turbo Boost code, which then results in Low Injector Flow code. After scanning and reset not able to recreate for a couple or three months. I write it off to Soft Ware bug. Just finished a 7 hour drive last week, normally once a month or so, so I do not see any forced regen messages. Heaviest tow is JLG scissor lift on JLG trailer, about 5k lbs. total. Switched to CJ4 5w-40 oil last year after FCA bulletin, was going to do it anyway I felt the euro spec oil did not have the fuel dilution capability that the heavier duty CJ4 spec oils do. I have to fight the wife to drive my own truck, she parks her Charger to drive my truck with any excuse. I park it in the driveway next to my 95 Chevy that has 397K miles on it so that it has a good example.
Leonard prowant
I wanted to take a quick poll and ask how many miles do you have and if you have any problems?
I have 15000 miles with no problems. I'm happy with my ecodiesel so far!
I've had my ecodiesel two years now with 40000 miles. No problems a joy to drive. We have two homes in Arkansas and Missouri. I pull a trailer with a 1710 ford tractor with loader and bush hog back and forth. Usually get 14 to 16 mpg. I run about 70 mph with plenty of power!
issanni
50
2015 that is 1 year old in August (left over bought in 2016), has 22,500 and counting ...... headed to Michigan from Texas in a couple weeks.
Zero mechanical problems, had both front wheel covers oxidize really badly from brake dust. Dealer replaced both wheels under warranty.
Stock Goodyear's sucked. Rears were worn smooth out by 20k miles and fronts still had good life left. Towing a lot of heavy trailers lately I think is what did it. Rears went from 60% tread to the wear indicators in about a month when I was towing. Put Coopers on it this time, we'll see how they hold up.
lucskoj
13
Just about 63k on my 14. I've had the SCR recall done along with the other recalls. Only other reason mine was in the shop was my EGT 1 sensor went out. Other than that the truck has been great. Planning to delete again this summer.
Medic201
25
20
2015 38k completely trouble free miles. Still getting 28-31 mpg on hwy hand calculated. The only issue was the center high brake light had a tsb for showing the right brake light out on the EVIC. I will say it is the best truck I've ever owned. IMG_2320.JPG
1,051
424
2015 38k completely trouble free miles. Still getting 28-31 mpg on hwy hand calculated. The only issue was the center high brake light had a tsb for showing the right brake light out on the EVIC. I will say it is the best truck I've ever owned. View attachment 1326
Good looking truck.
Tom McKee
I have 15000 miles but no problems. I'm happy with my ecodiesel so far!!
I have a 2016 Longhorn just over 21,000 miles, have done 3 oil changes so far with Zero problems.
fhedrickjr
75
23
Showing 16,987 on my 2015. Trouble free.
Tom McKee
2016 Longhorn, Air Suspension, Ram Box, 4X4, Sunroof, 21,210 Miles so far ZERO Problems, 3 Oil and Filter Changes, last one T6 Ro tella, 2 Fuel Filters.
Capt Tim
35
2014 Laramie Longhorn, 56k, 4x4 with rear air suspension and 2" lift front. No major problem - the DEF injector had to be replaced as it failed at 28k. Very pleased with truck. Was getting 27+ MPG in FL under no load. Changed OEM tires at 54k to Michelin 285/75/20 so my MPG dropped to 23;(. Does anyone have a tuner recommendation for our engine worth researching?
Capt Tim
35
2014 ED Laramie Longhorn, 63k, 4x4 with rear air suspension and 2" lift front. No major problem - the DEF injector had to be replaced as it failed at 28k. Very pleased with truck.
trace2008
19
close to 70k
cel for fuel pressure ckt a code comes and goes. it is a connection issue.
one exhaust fail resulting in filter 100% before i got to the dealer in Vegas
