Richard Kennedy
I wanted to take a quick poll and ask how many miles do you have and if you have any problems?
I have 15000 miles but no problems. I'm happy with my ecodiesel so far!!
I have 42000 miles on mine and have just had to replace the EGR and worped rear discs
DWalker
53
20
Yeah I was one of the possible crazy Ecodiesel owners that wanted to see how far it could go, unfortunately mine only made it to 55k miles
Let us know if it is ever determined what caused the fire. I wonder what FCA will say? With only 55,000 miles I am sure you insurance company will investigate and go after FCA.
Sent from my SAMSUNG-SM-T377A using Tapatalk
Denise Leismer
I have 2015 Dodge Ram 1500 ecodiesel truck. 55023 miles. Exhaust Filter 100% full. Service required. This happened to me 7months ago. I took it in to My Dodge Dealership and it cost me $500.00 to have them fix the problem. Now it’s happening again? I don’t have that kind of money to throw to Dodge Dealership. Is there anyway I can fix this myself ?
734
What did they repair for $500.00?
734
You cannot clean fuel injectors...You can only dismantle and R/R, and re-calibrate by BOSCH 825.
My guess on the Exhaust Filter 100% full. Service required needs WITECH to run system de-soot and check, I've done it several times to fix the issue.
Denise Leismer
You cannot clean fuel injectors...You can only disand re-calibrate by BOSCH 825.
That’s what
They cleaned the fuel injectors and that cost me $500.00.
That is what they told me at the dealership.
Denise Leismer
That is what they told me at the dealership . I paid $500.00 to get my truck back. They had it for almost two weeks.
734
I would ask for refund and state refunds cost $500.00 for asking, thats about equals their charge.
Denise Leismer
I have a 2015 with 4015 miles it is currently at the dealer for a bad dpf pump/injector - upon completing the repair they tell me that the dpf filter must be changed along with the pump as a precaution "per dodge" and that the dpf filter is made onto the dpf fluid tank and all must be changed together. ...sigh they have had the truck a week already . But other than that love the truck.
Was there any charge ?
No1up
Also, fule pump went out at 60k, and Exhaust filter full a few times but it went away. Extremely high fuel filter changes and oil changes.... I'm back to gas engine, oh how I missed $40 oil changes! Lol
Dans
I have 2017 with a p0299 code and understand it can't be fixedonly 3000 miles
1,282
354
So I'm going to go out here and disagree with the foam causing fires.. it's high density closed cell foam blocks on the top that do not pick up dirt or progressively make it more prone to heat. 81k and I pulled mine last night, only thing that I found was a completely clean fuel system because it protects that area from road grime. They will be going back on.
1,051
424
69,000 miles and not a hiccup.
Traction control may have prevented an accident this am. Lots of 4 lane construction in my area right now, couple that with the torrential rain we are receiving, it creates hidden hazards, mainly ponding in areas it should not. I hit an off ramp and dove into a standing pond at 60mph. The traction control kicked on and kept me centered in the lane. I believe without that I may have turned her around.
Happy owner. Plan to keep this truck for as long as I can.
Bullett313
Front end bolts loose and left 1 nut missing 1 bolt loose
Uo5 autopark functionality recall
U74 tailgate latch recall
U53 occupant restraint control module software update Recall
Leaking fuel from the where the fuel line connect
Coolant level is dropping (replace WGT)
Bullett313
Coolant level is dropping (replace egr)
