Injector code sticker location
CEC574
I am trying to find out where the injector code sticker is located at? Any help would be appreciated 🙏🏻
694
On each Injector, I have never used Alfa or WITECH to view current codes in the ECM/PCM, some claim to view them their.
67_Valiant
50
The HPFP cover has a label with all the codes on it. They are mashed together, so you need to "decode" it.
694
I don't see any Injector codes on this Ecodiesel 3.0 cover, How would you decode it with any accuracy?
876
431
Here's how to decipher the codes
694
Keep in mind that's OEM only......
I always Snap shot the Codes VIA Alfa or WITECH... Now if your the Original owner and virgin Injectors that works....
I never needed to mess with 3.0VM Injectors. Did 100s of 6.7s and others.
2018+ Require the bypass module or WITECH for changes, their May be other Aftermarket Tools, I just don't use them.
694
WOW, how hard would it have been to just 1 XXXXXX 2 XXXXXX etc... All owners will need to picture and save that sticker.....Heeeeheeee:):):)
67_Valiant
50
I know, right? Kind of like decoding the main/rod bearings from the block etchings. I guess everything needs a cypher haha
