Wow..... Yeah their prices are unreal. I bought a eBay 3in universal piping kit and a universal intercooler and made everything myself, so I replaced all the stock components, and made my own turbo neck connector that goes to the factory aluminum elbow and same on manifold
Nope, MRTuning shut off the CCV flow sensor and P04db code with it. I noticed in your pic of the modified OEM manifold, that you didn't replace the little bridges between the cylinders that hold down the swirl valve shaft. Maybe that was your sealing issue?
I would have been ok paying the $625 if everything were perfect and actually "Fabricated". instead Im stuck with a pile of 3" ebay tubing, and a bunch of silicone couplers I can't use.
I’m about to tackle this project myself after a diesel shop quoted me nearly $5000 due to the difficulty of a glow plug being in the way. Has anybody else had any issues with the glow plugs needing to be removed or breaking when you remove the manifold?
The intake can be removed without taking the glow plugs out. You also have a much better chance of getting the glow plugs out cleanly with the intake out. You will need to remove the low-pressure fuel return lines, a couple high-pressure lines and move the engine wire harness to one side. I also found it easier to get the back bolts out with the turbo elbow removed (2 allen-headed bolts hold it in). Last time I did it, it took a couple hours to get the intake out... and I was taking my time.
