Muffler Delete Day
Gator Chomp
17
Winter blend?
You know, I would not have thought about that winter blend cause its been around that mid 30's to lower 40's. And my norman fuel station hasnt put up any signs about blended fuel yet so I "assumed" he hasnt yet started. But that makes sense. Thanks.
Zecodiesel
13
Yes! I seem to have more giddy up for sure.....and damn it sounds jet like when I hit that throttle
Sounds great! Did you leave the resonators just before the exhaust tips intact? I’m looking at trying to do a full straight pipe, but it seems like that requires replacing everything from the straight pipe back to the tips. I’ve seen that for $479 and not sure if it’s worth it or not.
Zecodiesel
13
In Minnesota they run the winter blend from mid October to April I believe. Really sucks because a few of those months aren’t cold enough to warrant it, but the MPG’s suffer.
EcoLeesiel
108
70
Hey Zeco, yes I left resonators in place. Was worried about drone
Gator Chomp
17
I also left the resonators and put turndown tips on. I did get a hi-flow muffler just incase my mpg's dont come back up to where I was at before I deleted the muffler.
Zecodiesel
13
Would it be fairly simple to cut out the resonators and weld some straight pipe in place you think? I’ve heard it both ways. I definitely want to do a full straight pipe but will probably start with the delete pipe and muffler delete coupler like you did.
Gator Chomp
17
There are 3" straight pipe kits for the eco that delete the muffler and resonators. They are kinda spendy though. But on the up side you would be able to have a better selection on tips for better sound.
Gator Chomp
17
I put 3 inch turndown on my delete
EcoLeesiel
108
70
Sure do! I should have mentioned that they are 6" outlet with 4" inch inlet. I was able to clamp and weld them onto my factory chrome tips if that makes sense. They look totally badass and way more to scale in my opinion.
EcoLeesiel
108
70
I'll post a picture on Tuesday to show my handiwork from underneath
Zecodiesel
13
Just about to go ahead and delete the muffler to go along with my Stage 2 SFT tune. I already am fully deleted to the turbo so I figured lose a few pounds and see if I can't get a little more diesel sound out of her....
What delete pipe did you use? I can't seem to find any that will ship to the US. How did you get it? I was looking at the Flo Pro, but like I said, it doesn't appear to be available here.
EcoLeesiel
108
70
Here ya go......They have now made one specifically for our Eco's so no cutting to fit!
Zecodiesel
13
Awesome. Thank you. Which pipe did you use for the DPF delete?
