Oil additive
StevenB
62
29
Anyone run oil additive? In my old gas truck I was a big fan of the Lucas Heavy Duty Oil Stabilizer, have not yet added it to any of my Ecodiesel changes...thoughts?
4,296
1,133
Nope, and not saying I shouldn't. I just haven't in the last three modern trucks... I would love to know if it helps as if I can use anything to prolong the life of my vehicle, I will.
this is what is in the om
Materials Added To Engine Oil
The manufacturer strongly recommends against the addition
of any additives (other than leak detection dyes) to
the engine oil. Engine oil is an engineered product and its
performance may be impaired by supplemental additives
830
320
I've never used any oil additives in any vehicle. I just keep the oil changed well within the service and use intervals.
StevenB
62
29
Thanks for the replies. Like I said I have not used it in my Eco thus far and will continue with regularly scheduled oil changes
886
439
I've never heard of a case where an additive impaired engine oil. I've only heard of and know of proven cases that an additive improves engine performance. The best example is with the Ford 6.0 diesel. An additive such as Archoil's AR9100 is nearly a must to preclude stiction. I use AR9100 in my 2006 Ford F350 6.0 diesel and also in my 2016 Ecodiesel. It will not impair the oil and it cannot hurt the engine.
Dec 14, 2015
89
41
I am running the Rotella T6 oil it doesn't get much better than that. I do not use any additives in my oil, I do use different fuel additives to compare mileage results. So far a couple ozs. of good 2 cycle oil in the tank had the same effect as an additive that claims it boosts cetane levels.
