Oil in coolant.
cevans
141
90
The dealership "resident cummins expert" is usually the guy that gets stuck with Ecodiesels, even though they share nothing in common. Typical dealership crap.
I would stop driving the truck. The oil in the cooling system is drastically reducing the coolant's ability to transfer heat, so I would worry about hot spots etc. The oil is also affecting the viscosity of the coolant, which will have an impact on its ability to flow into and out of tight passages.
The pastiness is typical when coolant and oil mix together. There are some chemical interactions which results in a gray slurry.
Oil cooler is actually VERY easy on this thing. There is a lot of room on that side of the engine, and the assembly is only held on with 4 bolts IIRC.
TDRAM73
Ok so I took truck to dealer yesterday and told them my oil cooler was suspect. As I figured they called me 4 hours later and told me that yes it was the oil cooler and they want about $200 for cooler and $500 to install/ flush and refill system. That's no new tank but does include the already spent $105 for "diagnosis" lol. I do feel like I can probably accomplish this for less as I did see that the part has now dropped to $125 which recoups some of my "diagnostic" fee. But trying to find ultimate flush solution has me baffled. Some say wrong dish detergent etches aluminum and it looks like flush is an all day ordeal. Thinking about getting cooler, installing self and paying another shop (someone I know on my route, I'm a local UPS driver) to flush and theoretically saving at least a few hundred bucks?? Your thoughts?
cevans
141
90
I would suggest flushing the system with distilled water only. I don't like any sort of cleaning chemicals in the system. Any contaminants in the cooling system will cause internal corrosion over time. Flush as best you can, refill, drive and monitor. You might want to drain-refill in a few thousand miles if there was some oil that was still in the system.
TDRAM73
So I took truck last Thursday and had my mechanic swap out cooler/filter unit and then he put some macs radiator flush fluid in and after I drove home I flushed/drained it out. Ended up spending all day Friday pulling upper, lower radiator hoses and bypass valve out cleaned all hoses and tank off of the truck but did use dawn however rinsed profusely. It just appeared all hoses were lined with at least an 1/8" of oil paste. Pulled out thermostat and cleaned and flushed both directions thru motor and heater hose lines. Put everything back filled with just distilled water and poured in some more macs flush agent. Warmed up, pulled petcock plug, but still have a lot of oil in system. I'm curious is there an in-line filter I can get or remote filter kit to try to continuously filter coolant system?
arnie
There is a food item that makes water and oil mix together but cant think of its name .Most food industries use it and some people take it as a supplement .Will look for name . Its called Lecithin .
bianca demers
Have a 2016 ECO DIESEL ,Does anyone know it the coolant 3 way code p26ab.part of the engine. for warrenty.
287
I believe it is best to check with the dealer they deny most every thing
Aleman
I just found out that my engine oil has infiltrated into my coolant reservoir. How much did it cost you all to fix it?
727
In some cases its New Engine, Its extremely difficult to remove all the Oil that has leaked in the Coolant, Worst yet if Coolant leaked into crankcase.
Aleman
How would you know if it leaked into crankcase?
727
Its the Pressure, the Oil exchanger has failed, Generally the Oil pressure is much higher then coolant pressure, So Oil leaks into coolant, when no pressure exist, it possible with engine off for the coolant to leak into oil. I take it the 2015 is out of warranty.
Aleman
Yes it is and the dealership is charging me 6k. The part is less than $200. I might change it myself.
727
$6000.00 high IMO. I take they are replacing the entire coolant system including the radiator. I would Stop any repairs until Oil sample is taken and send to lab for Analysis, If coolant is found in triple digits PPM Most likely wear has resulted and if wear is found in the sample the engine is on it way to the recycle pile.
Aleman
They just said they were replacing the hoses and the oil cooler.
Aleman
I didn't agree for them to start any repairs on it, I have a buddy of mine who has his own shop and works on semis so it is no biggie for him and my uncle has been working on engines his whole life. Plus you guys are a great help. I'm just trying to figure out this whole situation.
727
Do the OA before repairs. Its just extremely difficult to get all the lube out, Just about everything needs replacing, Hoses, Radiator, Exchanger, 3-way Valve, Etc, and Hours of flushing out of engine.
Aleman
I'll definitely look into it.
