P019100 Fuel Rail Pressure Sensor "A" Circuit Performance-
729
Its not the filter its the CP4, Good Injectors are 300.00 each, the Pumps 650.00, Fass or dog are no good, the CP4 W/O GP requires 55PSI+ feed. and those worthless utility pumps cannot stop contamination. The stand-alone with commercial filter head Auxiliary is the only guarantee of stopping contaminate fuel. PERIOD!
CP4s are well known for being particle makers.
coorsman2005
21
I ordered all mopar parts So far
68211302AA injectors / 68211269AA pump.
I would like to call and talk to you tc and order the commercial filter kit if u got it. Then see if send the rails and lines to you if you could make sure there all good and clean before I go back together.
Also you did recommend to replace the lift pump also correct.
729
Those Injector origin is unknown, Pump is being dump on the market, I'm sure its 2-4 years old.
OEM don't mean nothing when it come to injectors, IMO those Injectors are house mans, you will have nothing but problems with them.
Bosch Part # 0445110522
