P20EE
AndyIRV
36
I have been getting an intermittent P20EE code. will be on for 1-3 days then go off for 10-100 miles.
code reader says SCR NOx Catalyst Efficiency Below Threshold Bank 1, primary fix replace DEF injector.
2015 with 54500 miles.
AndyIRV
36
9/24 is the first available at the dealer. They said a solid CEL I can still drive but if it starts to blink shut it down. I've put 700 miles in it so far in under 2 weeks.
921
335
If you pull the def injector and clean it that should solve issue. TCDIESEL will be able to walk you the process I believe it’s on another thread somewhere but I believe it’s pretty straight forward
AndyIRV
36
Thanks for the direction. I ended up purchasing a steam cleaner. it was almost completely closed off. steamer cleaned it in 30 seconds. No CEL since.
