So I have a 2015 longhorn ecodiesel and just had to do first oil change. Dealership put in pennzoil, this is ok correct? I know I've read where something was changed and now they want shell rotella oil. Should I have it changed or is it gonna be ok? Thanks in advance
As long as it’s the correct weight and has the correct additives I would not be too concerned but being a dealer I would think that they would put back engine specified oil
I just looked up the Pennzoil Euro Full synthetic, it is now available in the required 5w-40 for both the ecodiesel and the Cummins. However of the multiple specifications listed by RAM the oil only meets one the ACEA A3/B4. I am not sure if one is enough, the verbiage from RAM is "meet Material Standard MS-10902 and the API-CJ4 or ACEA E9/E7 or ACEA A3/B4 engine oil requirement..." The original oil was specifically the Pennzoil Euro 5w-30, changed to 5w-40 and at the time Shell Rotella T6 was the only product meeting the requirement in large scale distribution, I am fairly certain that there are several brands on the market now that fulfill the specification. The one difference of the Pennzoil product is that it is formulated from Natural Gas not from Crude Oil distillate. I would caution against a product that states it is for gasoline and diesel engines as the diesel engine need to suspend more ash content in the oil over a gasoline engine is drastic, as well as the additives in light duty diesel oil is deadly to automotive catalytic converters.
I have a 2017 and my book states Rotella 5w40 or similar. I think the specs changed in 2016-2017 from 5/30 to 5/40
Last time I heard The T6 5-40 was the approved/recommended engine specific oil for the eco. Like T126 said though and with all the problems you hear about, Why would a dealer of all people or private owner especially vary from the specific oil recommended? I could be wrong. I got T6 at advanced auto for $21 a gallon last oil change so ?
Specs were changed in 2016 to 4w40 meeting the MOPAR specs, that's key info , if you're doing your own service work. I keep a running spreadsheet of oil used, the filters etc. Make sure you keep receipts. also. You can also track them on the Mopar site.
Specs were changed again for the 2020/2021 Gen.3 Eco Diesel. They now want a 5W-40 synthetic MS 12991. Mopar Brand is the only one mentioned in the Manual. Rotella T6 does not show the MS 12991 on the Container. There are not many Oils available which meet the MS 12991 Specs, at least not where I live.
Posting just for reference for our members.
Needed:
1 1/16th Socket | 27mm in metric.
Drain Plug Size: 13mm
Mopar 6822 9402AA, Engine Oil Filter
Pennzoil 550023013-6PK Ultra Euro L 5W-30 Full Synthetic Motor Oil
--or--
Mobil 1 5W-30 ESP Synthetic Motor Oil
10.5 QUART OIL CAPACITY
***UPDATE***
New Requirement as of July 2016
You can now use 5W-40 synthetic engine oil such as MOPAR or Shell Rotella that meets FCA Material Standard MS-10902 and the API CJ-4 or ACEA E9/E7 or ACEA A3/B4 engine oil category is required.
See this thread for more info:
http://www.ecodieselram.com/forum/t...tion-requirement-for-ram-1500-ecodiesels.820/
View attachment 184 View attachment 185 View attachment 186
Fuel Filter Part #:
68235275
Does anyone know if these are the same part numbers for a 2021 EcoDiesel?It takes 5w-40 now.
is it difficult to remove the oil filter? I have heardit is easy to damage case the filter sits in when removing it.
The Eco is the easiest oil & filter change of any engine I've owned. The filter removal contributing 90% of easy. I don't see how you could damage anything removing the filter as you simply lift it up and out of the case. Loosen the cap to let it drain and you won't spill a drop.
Be sure to let the engine oil drain for at least 20-30 minutes as it is very slow draining.
Thank you sir. Yeah I was wondering how it would break but wanted to ask. I figured it wouldn’t.
The old Filters, Oil and Fuel, do not fit the New Gen3 Engine. I just received my new 2021 Ram Eco Diesel Bighorn and the Part No. are different for the new Engine.
Thx - that's good to know. Basically the same engine and fuel system. I wonder why? Just a design change
or ???
Good to know! Thank you
Does anyone use the Rotella T6 5W40 2.5 gallon bottle and one quart of the Lucas synthetic Oil Stabilizer? I've always just put the Rotella T6 in the "White Lady", but I'm wondering if the Lucas oil stabilizer would be beneficial? I know Shawn mentioned way back in the day that he used Rotella T6 and one quart of Lucas full synthetic, but I'm not sure if he meant a quart of the Lucas oil, or the oil stabilizer?
Why would you even think of doing that? Rotella T6 is a very good Oil in my Opinion. It is designed for a certain Purpose.
Adding anything to it changes the Structure of the Oil and might make the Oil perform worse then what it was engineered to do.
But then, that's only my Opinion.
OMG
Adding a quality additive to engine oil does not "make the Oil perform worse then what it was engineered to do." Where did you get that info?
As I said, only my Opinion. A lot of Automobile Makers are against Additives. Todays Oils with complex Additive Packages, deal with
Soot Control, Heat Breakdown etc. Add anything to it, you are changing the Structure of the Oil. And why would you. What is the Benefit
of the Additive? We will never really know. Plus the added Cost.
Then again, only MY Opinion.
Exactly - It's just your opinion, but you stated it as a matter of fact (with no facts).
And you just did it again saying, "Add anything to it, you are changing the Structure of the Oil. " Not true - it's called an additive because it adds to the oil, it doesn't change the oil's structure.
If you want to understand the benefits of additives, there's plenty of info if you take the time and effort to research it. Here's an oil additive fact. Engines that use Hydraulic Electronic Unit Injector Systems suffer from spool valve stiction. There's oil additives that prevent stiction and also cure it 100%.
