TX Dave
First up front, I do not own a Ram yet, I have an 2001 Duramax and I have always changed my own oil. I'm a bit confused here. I can use Rotella synthetic or regular Rotella, but from what I am reading the ED 3.0 only uses Synthetic. Might sound dumb but why is that? It is a diesel.
1,282
354
It's a low tolerance high efficiency engine with 10,000 mile oil change intervals with a 2.5gal oil capacity, this all comes from the synthetic oil, no Dino oil here. Consider this is a euro engine and high capacities with quality synthetics are the standard practice.
389
137
idparts.com has good prices on MANNs filters. Seem to be just as good of Chinese quality as Mopar...
Confused? MANN is a European filter manufacturer, we use them in our Land Rover, Mercedes, and BMW owners. Also industry statement that MANN is the manufacturer of the rebrand to MOPAR.
1,282
354
Quite true. The euro engines are advanced as diesel is the primary fuel there.
Even in the gasser, had mb and BMW vehicles in the past that were synthetic 10k oil changes, nobody even thinks to run Dino oil
1,051
424
Well they're labeled as Made in China, same as the MOPAR boxed filter over the counter at the dealership.
389
137
Wow! I will check our inventory, we have not checked a label in a long time. Company owner had toured the plant in Europe on a trip to England a few years back and we assumed production was still there. WIX has a part number for the oil filter and a special order for the fuel filter, both USA, we will definitely be looking into those offerings. Thanks for the heads up.
1,051
424
Good deal. Let us know what you find out.
389
137
Well guy's all the filters we have in stock are made in Germany. However the MANN-HUMMEL GMBH website does state that all MANN filters are made in plants worldwide, so our filters (include MOPAR rebrand) could very well be produced in a China facility. Just the luck of the draw I guess. Our MANN filters come with all necessary "O" rings and oil drain plug crush seals for each filter application and we have had no issues with them.
1,051
424
Thanks for the update. For the record, I have no issue with the quality of the MANN filter, no matter where it's been produced. And carry on with the good service @ idparts. You're the first place I look for maintenance parts on the truck.
Dan Walker
In light of the recent oil change requirments for my 2016 ECODiesel, some say there needs to be a software update, some say no. I also called two dealers. One said yes and one said no. So I'm confused..... I will put the new Rotella at my next oil change, but should I or should I not get the software update ?
Dan
bobcat67
223
88
Rotella is not the requirement, synthetic 5w-40 Diesel engine oil is, there is so many better alternatives than Rotella.... just my 2 cents.
1,282
354
The only change is cold viscosity, 40 opposed to 30. That's not really going to effect anything. The computer flash update is to keep engine rpms closer to 2k opposed to being able to drop into 8th at 55-60 and see 1400rpms where there can be some excessive load and engine lugging with a "less than desirable" oil flow.
So go ahead and run 5w40 if you like it's just thicker until the engine warms up. Will effect Canadians more than Southerners.
If you want higher rpms, your engine to Rev like you have 3.92 gears instead of 3.55's and only see 8th gear at 75+ then go ahead and get the 2016 dealer flash, or when and if it becomes available for the '14&'15 model years
Brokedownbutgood
289
103
You might want to do more research the number to the right of the W is hot weight left is cold weight. So 5W-30 and 5W-40 have the same cold flow properties just one is a little thicker at operating temps.
1,051
424
Exactly. So that's what doesn't make sense to me. FCA switched to a "thicker" oil @ temps when it seems there's been bearings fried. I'd think thinner, the better for getting through tight passages?
cevans
141
90
Both MANN-HUMMEL and OE Mopar fuel filters are contract manufactured by UFI Filter at one of their factories in China. UFI, based in Italy, designed the entire filtration system for VM, including the (unreliable) oil cooler. They also designed the fuel filter canister for Fiat/Chrysler.
SpeedReeser516
I see some talk about topside oil changes. I use to do this on my TDI through the dipstick tube, is that how it's been done on this truck?
SpeedReeser516
I do top side. Be aware, though, that you'll need at least a 4-foot tube for the RAM to get to the bottom of the oil pan. Most extractors include 3-foot tubes, those won't reach all the way.
Thanks, I'll have to measure my tube to be sure.
