Rear Differential Service
1,284
354
Thank you for the info on the rear diff. It looks like the front diff also has a drain plug just below the fill, is that correct.
Yes that is correct, but the front differential is an oddball weight from mopar, every bit of research that I did people just switch to 75w90. Also is that the bottle does not fit to fill, you can either use a gear oil pump or what I did was put a section of hose on a gear oil cap and basically fill from the wheel well.
mel
thank you for the info.
the front diff oil is spendy to say the least.
1,284
354
Yea just use a full synthetic 75w90. Seems to be the common replacement!
1,284
354
I had a photo of how I filled the front but no dice finding it. Sorry!
