Second engine and still the same scenario
Ramman18
So I’ll start by saying my engine was replaced at 67,000 miles the fuel pump recall was done with whatever fuel pump they put in less than 400 miles after replaced catastrophic failure, causing major issues that three different dealerships can’t figure out and scientist will not take responsibility for calamity damage they call it have been able to drive the truck with check engine light remote start cruise control. Nothing works just had another major failure low oil, pressure, light and major electrical issues happen yesterday and had the vehicle towed again. I don’t know what’s going on but we have to try and figure out how to hold them responsible. I’m probably out $30,000 on this truck with rentals repairs loss of work hotels tows not to mention my entire def system was replaced twice and probably needs to happen again
1,053
363
Sounds like a glitch in electronics or your dealers have zero idea what to look at
727
They are problematic in some/most cases; it will take someone that know the work arounds... Very rare to find someone in dealerships capable of reversing all of this, details will need to be shared $30K WOW...
Fat baz
Your not alone
My friend, I’ve been looking for two years for a used motor, after diligently have the services done on time, still paying for this piece of junk bought brand new, I stop and tell EVERYBODY I meet about how dodge are not standing by there product, I’ve looked at seven so called accident damaged vehicles only to find the engines are shot, then the vehicles damaged for insurance.
727
It was fiat That Brought the 3.0 VM Motori to Americas Soil, Ram was NOT in favor of the engine GM/VM designed the 3.0 VM for Euro Caddy's that never made it into production 2005-07. Plus, all ??? Americans that believe that Euro's technology is superior, ( Some products, engine, designed parts are better VM 3.0 was doomed form day one of production for Ram Truck/Jeeps) the VM 3.0 was to be placed into 3200LBS car, not 6200LBS truck and then rated it to pull 10K+ GVWR. Bed Plate cap's have proven to be problematic unlike Main caps, Once the Bed plate squirms around destruction shortly ensues. main bearing spec's need to be forgiving and spec correctly and kept that way or at some point its BOOM $$$$$
SeanPwnery
147
64
These engines have achilles heels - the biggest one is the oiling system - many which are neglected by people who never had to deal with diesel engine maintenance. The biggest problems I've encountered is TIPM failures (which has happened so often on this side of the pond that the cost to replace one has dropped nearly 80% due to demand), and electrical gremlins (generally solved by attacking the first code that comes up that solves all the downstream errors caused by the first code). If you're insane about your oil changes and using good quality filters, and staying on top of electrical foibles - they're not terrible. Mine just crossed 126k, same engine, sooted up intake, EGR disabled, and a new TIPM - and it's been ... okay so far. I'm running a now "extinct" SFT tune (I think the company no longer exists). I still need to do the CP4 fuel pump recall, and have been reluctant to do it since my CP4 is only a year old after getting grifted by the stealership.
I think the big thing here is, a LOT of dealerships don't know how to work on these engines. The other thing, the EPA forced emissions tech these engines were never designed to use which actually kill them. A good tune, some Rotella T6 15w40, and staying on top of electrical faults as soon as you get them seems to keep these things going. I've had mine for almost 4 years now, and after solving those previously mentioned faults - I've been ... "fortunate" so far.
Fun fact.. the Ford 3-liter "Powerstroke" is more or less the same engine we have with wider main bearings - with a good tune and properly anal maintenance and oil change intervals, they seem to work fine too.
