Second engine and still the same scenario
SeanPwnery
157
75
I had wondered if the air suspension was better for heavier towing. The 16 I bought for my wife had factory air ride but just deleted it. Bless her heart, she drove it a few times this winter with froze deflated suspension. Wasn't a comfy ride either when it did work. Found out both rear bags were shot
Dang, that's kind-of a shame - I rode on a bottomed out bag one time and I thought my spine was going to pop out the top of my skull, but before I gave up on it, I asked a few questions around here, and found the "aftermarket does provide" in this case. I was 100% ready to do the delete since the kits out there include 3-6 inches of lift, but I felt kinda bad losing all the controls in the dash - it came with it, maybe I'll let it ride a while until it pisses me off. I was able to score a new pair of them for a little over a hundred bucks and very quickly realized how easy the job of replacing them was. I even did a video on it if you ever find another one pre-delete. I did the one in this video and it took a little while since it was my first time, plus stopping to film it, but when I did the other side about two weeks later out of precaution, it was literally a half-beer job :ROFLMAO:
MrB616
25
I'm in Wisconsin and there isn't enough airline antifreeze out there to keep it from freezing up when it gets cold enough. She drove it all 4 corners down and even. One side up 🤣. The fuse for it that it blows too isn't the cheapest one out there either. Now it's just a beep and a brief service message when you start it
ok3
79
25
After a long look ... With 208Km on the clock.. I am thinking a detailed inspectionn of existing links...
Then good bags, and an adjustable ball end swaybar..
Then see where it stands..
Be interesting to see how much play in existing track rods etc..
Will advise after all done..
Spring is here and have to un-winterize the cummins powered n 04ram/bornfree toy.. With that stick and the 5.9 it is fun to drive even at 9600#.I have 4 solar panels and a mini split so it does pretty good except @ 105 in the summer. Then you must be on shore power.
MrB616
25
Sounds like a good plan
ok3
79
25
Your Better half is a keeper.. Sue would not- repeat would not- leave the driveway with any corners down! NOPE
I am going to replace one of the frack rods on each side to ball joints...I think along with the balljoint track rod that may positivly lock the rear down. Will be in may or so as first have to unwinterize toy rv......And I do not move nearly as fast as I used to...ha ha ha
