Service DEF see dealer
Bigo1120
I got the good ole “ service DEF system engine will not restart in xxx miles see dealership” message. I’ve changed the pump and the injector. How do I get the code to go away? Is there a special computer or button I need to push? Or do I have to go pay the dealership to do it ?
SCovelli
I know this is an old post but I thought I would reply.
You need to get a BT OBDII adapter and also an app for your phone to reset the code. A decent app is Torque. It is available for Android and Apple phones. The OBDII Blu Tooth adapters are readily available through various on-line vendors, just make sure it's compatible with Torque or whatever app you decide to go with. You can then read the CEL codes and reset them.
Dec 14, 2015
94
43
I had the same message show on my 2015 EcoD. After some research I removed the DEF injector and cleaned it with hot water. Replaced the injector after a few miles the warning went away and has not been on again. I have the date and mileage on record in a file but it is not available just now.
