I absolutely corrected the speedo. Not sure where I eluded I didnt.
Raising the truck over 5" in the front and the oversized tires killed my mpg.. even going back to the exact same type of nitto terra 4 ply tire (other than being larger 34" in diameter) only recovered 1 mpg vs 10 ply. the truck drives and shifts completely different now. I thought I could do better mpg wise with the 3.92 gears but it still took a beating.
That was on a long mostly highway trip though.. I only average about 19 in the city in the warmer months... I used to get like 23 in the city. Huge difference the drag from the lift and the gear ratio change from the larger wheels made.
Also your 33s are likely heavy 10ply tires.. im using the lighter 4 ply tires like oem since it only sees light 1/2ton pickup use I had used mickey thompson 34" 10 ply tires on mine for a few months while the others were on backorder.. I got just over 1 mpg back when going to the 4ply.
It used to upshift into 7th and 8th FAR sooner than it does now and hold those gears better at lower speeds. I can only imagine being lowered made a bigger difference than most people thing.
Well I have the SFT tune with the rally tune. It's not worth it. All I've had are problems sine I installed their tune. And can never seem to get someone on the phone. The mileage is BS no increase at all. When the tune isn't jacking up my ECU it's awesome. Powerhouse!!! But I'm in the process of swapping my ECU because my truck has had all kinds of issues like it just shuts off and says low oil pressure. 3 mechanics can't find any issues. All suggest it's the tune. After 2 years of fixing one issue only to have another I'm inclined to believe it's the tune. No refund policy is crap. Don't buy it.
