"Torque Pro" For Dummies? For Ecodiesel...
kd1yt
I'm incredibly pleased with my 3 week old 3.0d Ram.
I would like to be able to monitor boost and EGTs... and was looking into analog gauges (I am very technically oriented, but more in a hands-on/ analog way than a math/code sorta way)... but it started becoming clear that the Torque Pro Android App, which people can apparently customize to read all sorts of things in gauge-like format from the OBDii data, would be far cheaper and far less invasive...
So I ordered an OBD-Bluetooth adapter-
OBDLink LX Bluetooth Scan Tool
.. but... when I try to read up on 'how to' for the configuration of Torque Pro App (I registered and browsed their forums) its all at a level that's too complex for me to try to surf the early/steep part of the learning curve
Can anyone point me to a way to get acquainted with the way to get Torque Pro to display some of the specific parameters for the Ram 3.0d? I'm most interested in boost and EGT, very open to other things that may be useful but that I don't know about yet.
Thanks in advance!
AzRamDiesel
121
I found this on Google as I've been looking at setting this up.
PID: 016d
Long Name:Fuel RailPressure EcoD
Short Name: Rail P
Minimum value: 0
Maximum value: 655350
Scale Factor: 1x
Unit Type: kPa
Equation: ((D*256)+E)*10
PID: 016d
Long Name:Fuel RailTemp EcoD
Short Name: Rail T
Minimum value: -40
Maximum value: 215
Scale Factor: 1x
Unit Type: °C
Equation: F-40
PID: 016f
Long Name: Turbo Inlet Pressure EcoD
Short Name: TURB IN P
Minimum value: 0
Maximum value: 255
Scale Factor: 1x
Unit Type: kPa
Equation: B
PID: 0171
Long Name: Variable Geometry Turbo Position EcoD
Short Name: VGT Pos
Minimum value: 0
Maximum value: 100
Scale Factor: 1x
Unit Type: %
Equation: (C*100)/255
PID: 0173
Long Name: Exhaust Pressure EcoD
Short Name: EXST P
Minimum value: 0
Maximum value: 655.35
Scale Factor: 1x
Unit Type: kPa
Equation: ((B*256)+C)/100
PID: 0177
Long Name: Charge Air Cooler Temp EcoD
Short Name: CAC T
Minimum value: -40
Maximum value: 215
Scale Factor: 1x
Unit Type: °C
Equation: B-40
PID: 0178
Long Name: Exhaust Gas Temp 2 EcoD
Short Name: EGT2
Minimum value: -40
Maximum value: 6513.5
Scale Factor: 1x
Unit Type: °C
Equation: (((D*256)+E)/10)-40
PID: 0178
Long Name: Exhaust Gas Temp 3 EcoD
Short Name: EGT3
Minimum value: -40
Scale Factor: 1x
Unit Type: °C
Equation: (((F*256)+G)/10)-40
PID: 017a
Long Name: DPF Delta Pressure EcoD
Short Name: DPF Delta
Minimum value: -327.68
Maximum value: 327.67
Scale Factor: 1x
Unit Type: kPa
Equation: ((signed(B)*256)+C))/100
PID: 018b
Long Name: DPF Regen Mode
Short Name: Regen M
Minimum value: 0
Maximum value: 1
Scale Factor: 1x
Unit Type: Mode
Equation: {B:0}
PID: 018b
Long Name: DPF Regen Type
Short Name: Regen T
Minimum value: 0
Maximum value: 1
Scale Factor: 1x
Unit Type: Mode
Equation: {B:1}
1,247
340
I run torque pro and maybe I can get a screenshot for you but it's not too complicated.
I monitor my rpms, boost voltage and coolant temp, in addition to that I use the egt1 and catalyst1 temps to monitor regen if it's ever necessary.
I have a 2015and that is all that is available. No dpf temps or other Info, regen Info that I've found or otherwise. Specific to the scangauge but I guess it could be dependant on your obd reader. I use a cheap one but it works.
I know the older 13-14 rams showed more information to basic scan gauges but that is no longer from what I understand.
kd1yt
Thanks very much JDN- the main things I want to view/monitor are boost and the primary EGT (turbo inlet), which, if I understand correctly, is the data that's "EGT 1" As you say, being able to monitor the cat temp would tell me when a regen is taking place, which I wouldn't mind. So the more limited data for the '15s vs the '14s isn't going to disappoint me all that much.
My biggest question is simply not knowing how to activate/configure/display these particular readouts for this particular type of truck within Torque Pro; I get the sense that the configuring of the display (how you want it to look) may be fairly intuitive, but I am totally unclear on how to pick out/set up these readouts for the Ram 3.0d. Maybe it'll become clear to me once my obd/bluetooth device shows up (predicted for Saturday) and I download and start poking around set-up of Torque Pro- but when people launch into referring to PID# thus and such and various equations, I just am not following what it's about or how to do it...
Thanks!
1,247
340
you just long press the screen and select which style display you want. Small or medium is best to fit a few on a single page; then it gives you a big list to find which reading
Bruce
49
31
Any recommendation on what type of OBD to buy. Will any Bluetooth from eBay work?
1,247
340
I use the basic ELM it works fine for me got it from newegg for about 15$ about two years ago and have used torque for various vehicles that entire time
1,247
340
Used it on my old Mercedes originally; the wife's BMW x5, a Cadillac, a Pontiac, Chevy pickups, Subaru's, the Ecodiesel and numerous other vehicles I can't recall but I've never had issues with mine. It's not the fastest to connect and maybe it has something to do with limited egt readings (though I'm using the only operable readings from the trucks ecu) but it was inexpensive, highly customizable, and I bought a galaxy 7" tablet for my truck when I got it. It works perfectly.
And split screen on the tablet to run Google maps and torque worked fantastically
1,247
340
If you haven't found it yet I believe it's ELM 327
