Retired Bones
- Jun 15, 2016
- 33
- 7
- 2015
I have changed the oil early when I get high engine oil temperatures at my Dealers request. My next oil change will be in July after the fourth.
I just drove to so-cal without the trailer. North bound there are five steep climbs 6 degrees or steeper, some are short in duration. The Ashland grade is 7 degrees and lasts over nine miles. It is only 4400' at the top but it can be a grind.
There are tough grades in the Sierra's and the Siskiuyous in northern California. The Rockies in Colorado are a bunch higher.
If your truck is equiped with the selectable screens between the speedo and tack, one of them gives the four vitals for towing. Water temperatures, transmission oil temperatures, engine oil temperatures, then engine oil pressure. I have a 2015 Laramie, Ram, 1500 crew cab, with 3.92 gears, 275/17 wheels and tires. I do watch.
I travel with the above screen selected.
I still get the high13's when I tow. When I got home today after travelling the same "I"-5 route I have 25.8 mpg for 2,815 miles round trip.
I still challenge Fiat/Chrysler, fix the engine oil excessive heat. Your design puts way more heat into the oil than is SAFE.
