What's the best Engine Tune
pcatoe
60
Really curious about this new SFT deal I was leaning towards the HD with a new ecm, but I like the idea of having a hand held tuner.... so with this tuner what all can I disable, track, or monitor??
954
495
The SFT Touchscreen only holds your tunes, allowing you to switch between your stock tune and your SFT tune/s. You are not able to monitor anything or make any changes
tkabrick
Go with HD, there's is backed by lots of development and actual testing, not to mention the regen distance is vastly higher when compared to stock or SFT. There are also detailed comparisons done besides a seat of the pants comparison that shows SFT lacking, not to mention less soot produced is hard to argue against.
954
495
I have run both GDE and SFT ECU tunes and I have to disagree with your comments. Regens on the hiway are basically the same, there is no "vastly higher" difference. I agree that local regens are different with GDE easily taking the prize. SFT has used FCA philosophy on local regens. Because users feel that local regens should be longer intervals (GDE influence) SFT has been working on extending local driving regens.
The only "comparisons" that I'm aware of were basic performance charts done by GDE. SFT claims GDE used defective SFT tunes. This whole subject has been discussed, disputed and opined early on and I don't intend to resurrect it here, I'm just saying. SFT also did comparisons and found GDE tunes were so superior. My actual seat of the pants comparisons is that SFT is every bit as good a tune than GDE, maybe even better. SFT continues to improve its tunes and by the way, any SFT generated upgrade is free. I'm on my third free upgrade.
I agree, GDE tunes were excellent, and if HD is truly the GDE tune it would also be excellent. pcatoe will have a good tune whichever way he decides. It's important that any info provided to him should be somewhat accurate.
Here IMO is a real benefit of the SFT tune,
I had an occasion to take my truck to my dealer last week. In case he needs to access my SFT tuned ECU It was really nice to just put my SFT Touchscreen tuner in my OBD2 port and move my ECU SFT tuned back to my stock tune, it took maybe 3-5 minutes. When the dealer was finished I merely repeated the process to change the ECU back to my SFT tune. In the past with my GDE tuned ECU, I would take my truck to my Service Manager who would have his tech remove the GDE tuned ECU, reinstall my Stock ECU, when finished remove the stock ECU and reinstall my GDE tuned ECU and charge me $60.00.
I'd like to add that for me any tune that shuts off our EGR is worth its cost. The rest of the tune is just frosting on the cake.
pcatoe
60
Thanks for all the info guys. I do like the idea of having a handheld tuner. I’m not sure which way I am going to go yet, however I agree I think either one will get the job done.
954
495
I need to correct this sentence from my post #64 above. It should read:
SFT also did comparisons and found GDE tunes were NOT so superior.
954
495
Golruss
E-mail them or call them I think you will be very pleased with how they respond. I called them and talked to them they did not try to make me feel like I was stupid. They answered all of my questions. I also searched a lot of forums for negative comments about their tune. I found NONE. I am still saving up for my new tune but when I get ready to buy it will definitely be a GDE tune.
I had the same experience with GDE. Great people to work with. I did the engine and trans tune - no turbo lag, improved mileage and just a nicer truck to drive. Just wish I could remove the speed limit of 105mph.
2018 Ram 1500 eco diesel.
954
495
Can I switch the trans tune back and forth with the hand held tuner also? I already have the TT installed and it is absolutely awesome.
Yes if you have the SFT tranny tune. The SFT tranny tune, comes with its own handheld Touchscreen tuner.
SFT tunes & tuners
Tyhunter6
Would you be able to program/set up a second ECM with Alfaobd to program with sofa king. I’m curious if this would keep the ref lash count down on the ECM. Then in theory someone could keep a stock ecm as well as a tuned one with sofa king and switch them out for dealership visits??
954
495
I doubt it. You would have to ask SFT.
Mlauber
I just installed a delete kit from HD Diesel supply out of Manitoba Canada and I’m extremely happy with it so far. It electronically deletes the EGR.
954
495
What type of tuner did HD provide to tune the ECU?
Another forum is discussing the HD tuner. Some think it is a touchscreen tuner like SFT uses. One person swears it is not, that the HD tuner allows you to make changes to or modify the ECU parameters.
287
you chose the best one for tunes ,only one person will tell different, I use hd religiously they r the best
Mlauber
They sent me a tuned ECU and I just swapped it out with mine. I had to mail mine back to them for a core return fee.
954
495
Thanks, that helps a lot. We thought were now sending out the OBD2 tuner.
