Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
How is Polaris handling it? Sorry I don't know the owner aspect of it. I'm just a grunt in their manufacturing facility up here
2013+ rzr 900 & 1000 2 & 4 seaters were recalled for fuel regulators and missing a heat shield near the exhaust exposing the fuel line and wiring harness to extreme temperatures resulting in fires. Nearly 200k units.Didn't know they hard a burning problem?
38 FT 3 slide travel trailer
that looks like a Salem hemisphere 311QB which is over your towing capacity and is asking for trouble.
I guess the next question is, how does it pull and stop?
I pulled it 17 hours with no trouble, but I was a little nervous the whole time
It pulled fine, I avg 17 to 18 mpg pulling it 65.
What does the trailer weigh? From the one picture the truck looks a little low in the back. Maybe some adjustments to your weight distributing hitch will help.
WhooooaYeah I didn't have my stabilizers set. The trailer gross weight says 10700
Contrary to your observations I put an aggressive m/t Tire about an inch and a half larger diameter from factory and I wish I had the 3.92, I think the truck would be a lot happier. It is nearly never in 8th, almost impossible to hold at normal speeds before the switch, and the rolling resistance with 3.55s killed MPG'sThe ecoDs with 3.92 gears have quite a bit higher tow cap. than with 3.55s. I find that interesting as the gearing is the only difference in the specs. I compared. After a year of use I still think the 3.92 gears would by overkill in the 1500s, I'm very pleased mine has 3.55s.
I agree. Had I taken my time choosing a truck off the lot or built one, I would've went 3.92. They just get the train moving easier.Contrary to your observations I put an aggressive m/t Tire about an inch and a half larger diameter from factory and I wish I had the 3.92, I think the truck would be a lot happier. It is nearly never in 8th, almost impossible to hold at normal speeds before the switch, and the rolling resistance with 3.55s killed MPG's
