Engine Block Heater
Mharrison
373
105
Hence why people with short commutes have so many issues. One it's high soot points then you have 8 gallons of frozen fluid that is only thawed by your coolant lines. How long does it take for a 160-200 degree line to thaw an 8 gallon tank? Sure bet it exceeds a 5 mile commute where the truck won't even see operating temp
The SCR doesn't really have anything to do with soot content though that is handled in the DPF filter SCR mostly just drops your no2 levels
Jun 1, 2015
39
Yeah. I was thinking I read in the manual, or the guys at the shop told me there wasn't any reason to heat the DEF. That the only think you needed to make sure of was not to fill it full. Because then your looking at a tank bust upon freezing.
1,051
424
Tank burst - Have you heard/seen this scenario? I find this hard to believe 1) being its a plastic tank that would expand and 2) I don't think it's possible to fill it so full there's no room left for expansion.
I'm not busting your chops, I just can't buy into that theory I guess.
1,264
345
Yeah if tank burst was a serious possibility it'd have a fail safe to only ever be 3/4 full or it'd be a terrible consumer case. I never thought twice about a tank burst scenario. My only concern regarding the DEF was the amount of time it takes to thaw
seiko
263
57
I have a block heater, came with the truck and along with the cord. We had weather -27C and whatever the wind chill factor. So, far, I never had to plug in. Just before leaving, I use the remote, and within seconds it start up.
I suspect, having the engine covers, keeps the engine a bit warmer, especially if it windy.
So far, it start up, very close, like any other gas vehicle I had. I was expecting long waits, but it hasn't happen.
Since I have put in a tank full of Shell v-power, it hasn't been cold like that, but they claim, it would help in starting. Time will tell.
Never had any indication of DEF freezing or any warnings. Only filled up once at Flying J truck stop. Added 10.00 worth, it gave me 3/4 tank full. At 18000 KM, it now reads a little below half. When it really cold, the level drops a bit, then after warm up, back to normal level indicator.
Allen Peter
Book says plug it in a couple hours before you need to start engine , anyone leaving them plugged in all night?
4,333
1,145
A lot use a timer and have it kick on a few hours before. That's the most efficient way..
marcm
26
First off, my apologies if this is already a topic. I did a little research before starting my own thread.
I'm not sure if my Laramie Limited came stock with a engine block heater. Like many dealers, there sales people and mechanics were not able to show me where. Can anyone make a suggestion on brand and recommend temperatures in which it should be plugged in. Thank you!
From what I was told all eco's have a block heater but depending on where it's purchased it won't always come with the block heater cord but you can get one at most auto part stores. I'm in northern ontario and get a lot of -30 and colder weather and barely ever plug mine in and have not had any trouble starting but to be on safe side -20 would be a good plug in temp.
1,264
345
I keep mine plugged in all of the time. No sense having to heat the oil and coolant from air temp every time you jump in. Plug ins at Work if it's under 50 degrees I plug it in. Electricity vs fuel for engine warm up. Pick your poison
1,051
424
When the garage starts getting below 50F at night, I plug it into the mechanical timer set for about 3 hrs before I leave for work. No problems.
1,264
345
Also on a side note, my mentality is that considering coolant lines are ran through the DEF tank I figure any time it's below 13F and the def is starting to freeze having the coolant warmer to keep that tank partially thawed can only be beneficial.
Bigjima
Mine was working great this morning 9 degrees here in NC.
justlucky
77
Kat's 28500 18/3 Gauge, 5' Straight in Replacement Cord &Park Power by Marinco 150BBI.RV RV On-Board Charger Inlet (15-Amp, 125-Volt, Black)
I picked up both from Amazon. I cut up a 4 inch piece of very thin maybe 1/8 of a inch sheet metal to put behind the plastic on my bumper, to make it the outlet more secure when I put in or pull out the cord. I wanted a little more beef behind the plastic. You will need to cut the original male plug from the Kat’s heater cord, be careful here as it was a tight fit. Then wire it with the Marinco "outlet", the Marinco takes a 1 7/8 inch hole to insert it into the truck, and I had a hard time finding this bit, I went to Lowes and home depot and they did not have it. If you do not have one I suggest you pick one up from amazon. The metal ring that screws from the back of the marinco unit to squeeze it in tight I had to tighten first and then I predrilled into the metal so I could inset little screws, they also will perform as an anti spin for the metal ring in the back. This job was done with the credit to the people on this and other forms shareing there ideas. I really wanted to put it in the back, to keep it away from the rain and snow. But job that was way too much for me
justlucky
77
I ran the heater for two hours , and I am not sure if it works, here is a picture of the temps, what do you think.
Cmartin
My truck didn't come with a block heater cord, but the heater is there ready to be connected. First winter I owned it was the mildest on record and I ddint miss it at all. This year was a different story! I never want to hear that diesel fire up at 2 degrees again! Sounded like the devil was being tortured in my driveway! Lol. I'll be installing the cable and using it this winter.
4,333
1,145
You think that's bad, try running a diesel on gasoline. :D
Bri
I'm in Missouri and the temp has be 12 degrees or less. I brought the block heater cord and installed it the yesterday. My question is once it's plugged in what should temp?
1,264
345
With an ambient temp of 12 you might see coolant temps of 45 or so when you start up your truck
Bri
Ok, just by turning the ignition key on and checking my coolant temp is 100 and the oil temp is 104 with the outside temp being -4
  • pic.pdf
