Injector pump failure.
718
Its easy to check, takes all of 5 minutes..
Joebet
They made it sound like they weren't sure but were hopeful. The dealer says it runs but can't get it to run right. I will have to ask what that means after the fuel pump is replaced
Bradyhond
Sounds like tone ring failure, why are you/they replacing Injectors Pump, If Dealer is that incompetent you will have future issue's.
Even an expert like Myself has label this engine as a failure and will never own another 3.0VM.
Did the dealer check lift pump pressure, the CP4 takes maybe 10 minutes to check health on engine. LMBO on Injectors.
Can help me i remplace manifold now wont start
I chk with scan tool x431pro when cracking rpm dont move
Fuel rrail pressure dont lift presure when crack ....arround 12.5 bar
Help.me
