New Ecodiesel Owner
954
495
My sway control is supposed to be built in my hitch. I’ve had this adjusted so tight that the camping people said I would ruin the brake on the hitch. But even then it didn’t help.
That's a great hitch but the pictured head is not a Sway Control head. You probably already know, when properly set up it should nearly lift the truck rear to its unloaded height. The bars should be parallel to the trailer frame. not angled down or up and the trailer should be level or down at the front. If up from level at the front you will get sway.
Whoever told you the 1500 could tow 12,500 was very wrong. Your tow capacity will vary depending on how the truck is equipped, but I believe that 7000 is near its capacity, IMO that's too much for any 1500, especially a 3.21 rear end.
Kenny P
13
Didn’t mean to put the options twice, hope I didn’t offend you. Sorry about that. I did call my Ram dealer and talked to service about towing weight limits and they again said 12,700 (I thought it was 12,5). I also know what was in my owners manual that’s why all this concerns me. I’ve pulled my camper to Rapid City SD and back (1,800 miles one way) with no problems, other than the sway. Hopefully I won’t have other problems but do realize I should probably go with a 2500 or higher for this or other campers.
Dec 14, 2015
94
43
Very few Ecodiesels have the 3.21 differential as it is very low for an engine that pulls this well. It would also make it hard to get any decent mileage on a road trip. I have found the best set up for me has been air bags in the rear springs with 8 to 10 lb. of air and 10 ply tires with about 75 lb. of air on the rear. The door sticker doesn't show 75 lb in the rear but the 10 ply tires reach the maximum carrying capacity at 80 lb. The truck handles and rides pretty well with that set up and I have towed my large camper to Maine and the other direction to western Florida with no sway issues. I did have 1 trailer that had the wastewater tanks all the way at the rear and if they needed dumped I could tell when towing. When equipped with a factory tow package these trucks have an amazing tow capacity.
Happy motoring
Ramsey#1
63
20
Happy motoring
I actually run around 25lbs in my air bags. The only thing I noticed was my transmission temperature on long pulls will get up to about 220 degrees
Kenny P
13
Happy motoring
Thanks for the information. My recent trip, where my turbo tube clamp burst, I put 50 pounds in the rear, have the stock tires and my camper have the bathroom in the back, but we never have anything in the holding tanks.
Can I ask the gear ratio of your vehicle?
Ramsey#1
63
20
I have a Laramie with the tow package and 3.92 rear end. I get between 13-15 mpg at 65 mph.
Cbelt
21
If you haven’t done so already a set of air bags in the rear springs really helps when you’re towing. I have a 2017 with 95,000 and we pull a 2013 22’ Forest River all the time and it does a great job 👏
Try road active suspension
IAmTheBestICan
Ok your trailer has 660lbs of tongue weight and is about 6000lbs empty that’s pretty heavy. Keep in mind you can only carry about another 700 pounds or so without being at your maximum capacity.
I thought the towing capacity was 13,000 lbs. Is that not right?
Ramsey#1
63
20
I’m sorry I don’t remember if you said you have the heavy duty tow package and a3.92 rear axle. But that’s also the maximum and I don’t think it’s a great idea to be at your maximum
IAmTheBestICan
I am not the guy you were responding to; just read the post and commented. I wasn’t aware that the 13,000 lb towing capacity was only if you have the heavy duty tow package And a 3.92 rear axle. I don’t actually know if I have that or not. I guess I will call the dealer, give them my vin, and find out. I have a 5,000 lb trailer and I assumed I was WAY under my towing capacity because I read on the dodge website that the EcoDiesel had a 13,000 lb towing capacity. I thought that applied to all 2022 EcoDiesels (that’s the year I have).
A standup guy
33
An easy hack. If one side of your trailer is a lot heavier than the other I.E. it has a slideout or kitchen and refridgerator are on one side, Increase tire pressure on that side or lower pressure on the other. Evening out the resistance on the tires should help with sway. It really helped on my small R-pod.
SLT
47
A 3.21 Rear End is not for towing, it’s for best Fuel Economy. Definitely not the right Truck to tow your Trailer.
IAmTheBestICan
How much did it cost to put the airbags on? Also, where did you get it done? Did they do a good job of installing the switch in the dash?
Ramsey#1
63
20
It does a great job towing the trailer; no issues so far.
I was able to put mine in myself. But I fill them in the back through a threaded type of valve stem in my license plate. Do some research and get the highest capacity available. Mine are older and can only hold about 30 lbs of pressure maximum. Good luck
