New Ecodiesel Owner
Ramsey#1
63
20
I was able to put mine in myself. But I fill them in the back through a threaded type of valve stem in my license plate. Do some research and get the highest capacity available. Mine are older and can only hold about 30 lbs of pressure maximum. Good luck
By the way I’m at 104,000 and going strong. 💪
Dwight@Mobile
Bought a 2021 1500 Limited with the Eco last year to possibly pull a trailer. Well, I screwed up because it has a 3.21 rear end. so obviously I did not do my research.
After educating myself about the 2026 Ram 1500, it is amazing how many different things affect your tow capacity. A 2026 Ram 1500 can be anywhere from 8,000 to over 12,000!
MrB616
25
Have to look too, the truck sits on top of coil springs not leaf spring like the good old days. Even tho it has the rear trackbar, to keep the rear end centered, they have rubber bushings to mount to the rear end and frame. I have a 15 with air bags in the coils and it is a nightmare over 45 mph if it's windy out to pull my Keystone No matter the pressure in the bags even with the weight distribution hitch. I have pulled that camper with my old 2004 ram 1500 at interstate speeds with very little wiggle. I know my camper is very close to weight capacity and that doesn't help.
