Tire size
StevenB
62
29
What is the widest tire that can go on an 18x9 inch wheel? My Eco has a 2-inch leveling kit installed and clearance doesn't seem to be an issue, within reason.
Right now my 275/70 KO2's seem small in the wheelwell. Id like to go a little taller as well as wider if possible. Suggestions?
1,248
341
I don't think you can go as wide as a 305 with factory wheel offset but I believe 285-295 can fit, and with a leveling kit a narrow 35 seems about as large as you can get, fits my wheel well nicely
1,248
341
I guess I've seen a 305-50 (I think) maybe it's 55, but it's way way fatter of a tire than the rim so you get no side wall. That being on a factory 20" rim, I think the 8" wide standard 5 spoke chrome clad, but some forums I've read the 305 rubs the upper control arm there isn't much room there, it depends on the offset of your wheels.
Brokedownbutgood
289
103
18x9 is not a oem size for theses trucks so we would need the offset to even have a clue as what well fit.
Ofishl1
93
NITTO G2 295 65.my next tire ...I HAVE 285 75 20 KO2s..the Nittos are 35inch tall and 11.7 wide....KO2s are 34.6 and 11.2
1,248
341
Thinking about going to the ridge grappler next, still 275/65. See if it's less noise than the stt pro. I want something more aggressive than a g2, so Stt Maxx, ridge grappler, or another set of pro's
Ofishl1
93
The BFGs have beenn the GoTo tire for me for 400,000 miles of 4x4s and have never failed us...great tires ..but here in Az the new KO2 seems to wear faster over the summer heat than the older T/A did ...real or imagined its time to change...with the new lift we can go with any size.
I find it is hard to find a 295 65 in A/T where it was not an 80+lb tire.
1,248
341
Sheesh! 80+ lbs? I find the 60-70# 275's a bit excessive
Ofishl1
93
Yes..weight maybe no concern on a 2500...my buddies cummins..he runs the G2 in 295...he only has 10,000 on them tho..and complaining they are wearing down quick..he also said they wandered around the road until they were broke in..in Arizona.. road heat is an issue tho...my KO2s will make it to 40k.. maybe..at 6/32 now at 28,000k
1,248
341
If you don't mind road noise these cooper Stt pro's are nice. I have 34k on the lesser half of the usable tread
1,248
341
I realize I'm colder climate but that's looking like it will be pretty darn good tread life overall
Ofishl1
93
For this new vers of KO I think so, this with religious rotations, the older version BFG KO must have been harder rubber, they ran forever.
1,248
341
Yea I've heard that of many many people that were religious to those tires, but they softened the compound and added some siping so get snow certification as an all weather tire. They also get torn up on gravel pretty bad. The general grabber is supposed to be the old bfg ko mold, I wonder how close they hit with the compound.
Ofishl1
93
they sure do look a lot alike...bfg_alterr_tako_pdpfull.jpg ge_grabber_at2_owl_pdpcrop.jpg
1,248
341
Wow.. didn't know the grabber was that close to the BFG's.
Yea man, the budget brand scares everyone off but a lot of guys in the Tire shops around here use them, saying it's just the original ko.
Ofishl1
93
well they are close.. but the center block pattern is slightly off and edge siping..likely to avoid patent infringement if its still valid..I went thru 3 sets of the BFG KOs on an earlier 4 wheeler..and they wear great.
