Will this threaten the engine??
I had one break in the head also. They were able to get it out without lifting the cab or anything crazy. I think they ran a heli coil or something in it after soaking overnight with penatrant.
If you loose the same one a second time (not likely) it’s a sign if put with a slow coolant loss and a little white smoke at start up that you have a seeping head gasket. In which case Titan polymer sealers not available in stores see there site has a viable solution. It’s made fresh for you because it has a short shelf life to be mixed & used.
i have a 2017 ecodiesel. my question is can i use my remote start when its cold outside..meaning will the glow plugs work without being in the truck?
Yes, the computer will automatically delay starting with remote start. Also if you have push to start it will always delay cranking when necessary without you having to wait for anything.
